Oil pan extension with the cooling tubes
beemersanducs
Post by beemersanducs »
Hi, can anyone tell me the pros and cons of the oil pan extension with the cooling tubes?
Re: Oil pan extension with the cooling tubes
Post by Garnet »
Reduced ground clearance, haveing to modify the center stand and an extra gasket that might leak are the downsides.
On the upside it is a low tech way of cooling and adding oil. It also adds crankcase volume which is needed on the 900 and early 1000s.
Unless you are draging a chair or raceing it is not realy needed. Oils today are light years ahead of what our bikes where designed to run and can stand much higher temps than 15 years ago.
twist
Post by twist »
Garnet wrote:Reduced ground clearance, haveing to modify the center stand and an extra gasket that might leak are the downsides.
but they look cool! :mrgreen:
guy
Post by guy »
In my local it will soon plug with horse exhaust.
Guy
beemersanducs
Well I have a cafe R90 with extensive mods (both frame and motor) that I already have a late model deeper pan on but it seems to be pretty hot running at times, timing and jetting are spot on (Mukini's and Omega) Cool factor is important but not as much keeping the oil cool!! If I could figure out how to post a pic.......
Deleted User 287
Post by Deleted User 287 »
beemersanducs wrote: If I could figure out how to post a pic.......
Go to this thread and skip to the 3rd post:
http://boxerworks.com/forum2/viewtopic.php?f=1&t=3453
beemersanducs
Heres a pic of my Cafe
2valve
Post by 2valve »
hi to all, had one on my R90/6 a long time a go , one thing that i do remember though it was bloody heavy in weight. it looked super cool i thought.
twist
Post by twist »
beemersanducs wrote:Heres a pic of my Cafe
I'm very interested in the rear mud guard. Can you tell me more?
Post by Garnet »
As in: Where did your battery go?
