Motor wont rev past 3000rpm
lelocp
Post by lelocp »
I got my bike started for the first time since I acquired the bike. Now the bike starts up every time with no problems but my issue is that every time i rev the bike up, it wont go past 3000rpm's. I dont know too much about carbs so any input would be great.
Deleted User 62
Re: Motor wont rev past 3000rpm
Post by Deleted User 62 »
Do you have a strobe timing light? See if you are getting full advance; the "F" should be centered in the timing hole at around 3000 rpm.
lelocp wrote:I got my bike started for the first time since I acquired the bike. Now the bike starts up every time with no problems but my issue is that every time i rev the bike up, it wont go past 3000rpm's. I dont know too much about carbs so any input would be great.
We don't know much about your bike, such as year, model and mileage. Any history might help too.
lelocp
Post by lelocp »
It's a 1971 bmw r75/5 with 26000 miles. i took the bike out for a spin and it did in fact go over 3000 rpm but every time I accelerate the motor seems to hesitate.
Roy Gavin
Post by Roy Gavin »
Float levels would be first, then fuel flow.
Snowbums site has info on setting/checking both.
chasbmw
Post by chasbmw »
+1. Gavin
Charles
1975 R90/6
Rodent has made a nest in the filter area?
Slashsevenpig
Post by Slashsevenpig »
sticking carburetor slide/cracked vacuum diaphragm?
Jean
Post by Jean »
If the bike has been sitting for any length of time, the jets are probably gunked-up, especially the main jet tube. Of course, ther might be a problem in the distributor that prevents the weights from advancing the spark.
It looks like you're going to have to learn about carbs, or find someone who does know.
How long has it been sitting around?
Are you in the AIRHEADS?
Where are You so someone might be able to provide assistance?
lelocp
Post by lelocp »
I went and got my carbs cleaned and now the motor runs fine until today. After a ten to fifteen minute ride, the right cylinder begins to miss (losing power) and then eventually wont fire at all. I checked the spark plug and it's wet and black, so I know im running rich. Could that be the culprit. I noticed if i wait the right cylinder eventually fires up.
