On oil filter change
Re: On oil filter change
A chopstick would probably make a good tool.
MMMM Chienese take away. :)
Zombie Master wrote:
Major Softie wrote:
Zombie Master wrote:BTW will you guys re-use the big white O ring and shim if they look good?
The BWORing can be re-used but only by Ron Jeremy, and not for his oil filter.
Have you seen the size of that O ring? RJ must be a girthy fellow! :shock:
His girthiness made a career for him.
Garnet wrote:A chopstick would probably make a good tool.
Vote here for the best Chinese in Victoria British Columbia:
Golden City
ME 109 wrote: I have tried using a skewer before, but the chicken obscured the ball.
That raises questions that aren't even suitable for the Speakeasy. Dude, you may need to seek some help!
vanzen
Post by vanzen »
ME 109 wrote:Youse guys are funny.
I don't have wooden skewers for probing my ball, but I do have a chainsaw file.
Ideally, the probing object needs a flat on the end..................much like a chainsaw file really..
The 'flat' prevents the end of the 'probe' from easily slipping off the ball....
Remove the chicken, reverse the skewer, and use the flat end.
[quote="vanzen@rockerboxer.com"]
Exactly Vanzen.
And don't forget to wear safety glasses to prevent poking one self in the eye with the pointy end!
ME 109 wrote:
vanzen@rockerboxer.com wrote:
Exactly Vanzen.
Of the chicken?
Jaun should allways wear where saftey glasses when working without a net.
Major Softie wrote:
Of the chicken?
Nah, the pointy end of the stick. The pointy ends of the chicken were removed, so to sbeak.
I used a wooden chop stick. Had the nice flat end. The ball is still n place with light spring resistance. I installed the filter with new white O ring, new shim, and new gaskets on the filter cover and sump plug. I am most virtuous. 8-)
