MORE Problems found!
KellyVB 75R90S
Post by KellyVB 75R90S »
Found this crack in the dog ear after I put the clutch stuff back in. The crack gets wider when the clutch is operated. I'm sure it's just a matter of time before the ear breaks off. Can this be welded? or maybe try quick steel epoxy.
Re: MORE Problems found!
There is a "bodge" I suppose that could be tried. Find a steel strap the width of the standoff ear and wrap around the curved end. Then in a couple of places, drill through the strap and tap into the aluminum for a screw to hold the strap in place. Seems like it would be enough to keep the curved end from opening up under load.
Aluminium alloy can be welded with a Mig or a Tig but you need someone who knows what he's doing. That ear takes quite a bit of pressure when the clutch is pulled...
KellyVB 75R90S
Got her welded, Best 60 bucks I ever spent. Let's hope she holds. Gentleman that did it has been welding for 50 years.
How's the hole? Did the heat have any effect on how the pin that rides in hole?
Looks a decent job... I hope it lasts..
KellyVB 75R90S
It's all back together and clutch works like a charm.
KellyVB 75R90S wrote: Mon Nov 02, 2020 11:08 am It's all back together and clutch works like a charm.
That's great... as long as it works like a clutch as well... ;)
dwerbil
Moderator
Post by dwerbil »
Good deal!
Click for pics
Randy in Round Rock
