Turn signal relay
jagarra
Turn signal relay
Post by jagarra »
The turn signals on my 74 R90/6 don't blink. Pulled the unit from the headlight shell and opened the case, played with the gap on the pull circuit, worked a bit better, but no cigar. Checked the fiche and found 2 relays, one under general electrical called a hazard relay for about $27.00 and the other in the headlight picture called a hazard relay for $94.00. Are they the same or am I required to buy the most expensive unit.
thanks,
jagarra
Re: Turn signal relay FIXED!!
Post by jagarra »
Well. played with the relay, checked the components and everything looked, good, no shorted transistors or capicitors. messed with the relay gaps and no change, it just vibrated. Found a link to a thread discussing possible bad grounds, so I cleaned the main wiring ground, placed a nice star washer at the point of contact to frame. No change!!!. So then I resoldered all the connections on the PCB for all the components, installed it back into the bike and it blinked like it should have. :D :D
Unclviny
Post by Unclviny »
"it just goes to show ya, it's always something" - Roseanne Roseannadanna
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
Post by Deleted User 62 »
Unclviny wrote:"it just goes to show ya, it's always something" - Roseanne Roseannadanna
"Never mind." - Emily Litella :lol:
wookie
Post by wookie »
"What's all this fuss about Eagles' Rights?" - Emily Litella
"Get off that bloody computer"- my wife.
What's all this talk about violins on tv?
What's all this fuss I hear about endangered feces?
What's all this fuss I hear about making Puerto Rico a steak?
What's all this fuss I hear about 1976 presidential erections?
What's all this fuss I hear about pouring money into canker research?
When Jane Curtin called her phone:
Hello, this is Emily Litella. I'm not home right now. But I will call you back as soon as possible. Just leave your name, number, and what time you called, after you hear the sound of the jeep.
-Emily Litella-
twist
Post by twist »
jagarra wrote:The turn signals on my 74 R90/6 don't blink. Pulled the unit from the headlight shell and opened the case, played with the gap on the pull circuit, worked a bit better, but no cigar. Checked the fiche and found 2 relays, one under general electrical called a hazard relay for about $27.00 and the other in the headlight picture called a hazard relay for $94.00. Are they the same or am I required to buy the most expensive unit.
thanks,
I bought the cheaper part, it's solid state and works, (worked until I dumped the bike) just great. Let me get the part number for you if you still need it.
