What is this tool used for?
Toofar
Post by Toofar »
Trivia time: What is this tool used for vis-a-vis an R75/6? OAL is 21" and the notch is at 20".
Thank you,
Lost and clueless.
[img]http://img.photobucket.com/albums/ ... .jpg[/img]
Been so long I had to re-register.
Re: What is this tool used for?
Hmm, the notch looks to be carefully made. I've been fondling working on a /6 for some years and can't think of a use for that special tool. I will follow with interest. It might be useful when I need to beat myself up for making an expensive mistake.
ps: Is there a prize?
Toofar
Post by Toofar »
I've never had to use it, either. I think it's some sort of propping device. I've been all over this bike for years and have no idea what it does. I got it with the bike back in '02. Got me.
grant81rs
Post by grant81rs »
Gidday,
Ah yes... You slot your sausage in it firmly and cook over hot coals in a vertical postilion, don't ask me what the small hole does?? :shock:
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Swing arm alignment?
bbelk
Post by bbelk »
It is an unfinished strap spreader. I have one just like it with a notch on both ends. When I need to do wheel work I raise the bike up on the lift, run a strap through the back wheel and up to an overhead rafter. I then drop the lift until the bike is suspended. I use the spreader to keep the straps from chafing the sides of the fender and seat.
1979 R65
[quote="bbelk"]It is an unfinished strap spreader. I have one just like it with a notch on both ends. When I need to do wheel work I raise the bike up on the lift, run a strap through the back wheel and up to an overhead rafter. I then drop the lift until the bike is suspended. I use the spreader to keep the straps from chafing the sides of the fender and seat.
Pic doesn't show anything! Cute redhead though.
bbelk
Post by bbelk »
Zombie Master wrote:Pic doesn't show anything! Cute redhead though.
Thats all she would show me.
1979 R65
Toofar
Post by Toofar »
The boots can stay on, though, right?
Anyhow, here's the nearest thing I can find for the tool. It appears to prop the bike up level (both wheels off the ground) when used with the luggage rack.
Why would that be necessary? If I remove the rear wheel, the bike will tip all the way onto the front wheel, rising off the tool so, I don't think it's needed for wheel removal. I also tried to see if it was to wedge the stand (rather than having to tie it forward for safety). No go, there. Fascinating. The O.O. took a little time to make the tool as though it would be very useful/handy.
Hmmmmmmmmmm. Could it be to prop the bike with BOTH wheels off? The front would have to be removed first, I suppose as the bike tips onto the front wheel if the rear is removed.
Post by Rob »
You know? That looks much nicer than my 2x4 that I stuck under the rear fender when I would drop the swingarm to pull the gearbox!
I think you have a winner!
