Handlebar Master
Norm T R100T R1150RT
Handlebar Master
Gatherin an assortment of parts to do a conversion from the undertank - purchased a double banjo bolt - 10mm x 1.25 Double Bleed - length is good, thread size is too coarse - what is the proper designation / size to get the correct thread pitch ? Thanks
Norm Taylor
1980 R100T Airhead
2002 R1150RT Oilhead
1950 HD Panhead
Southern Maryland, USA
2003 K1200 GT
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
Re: Handlebar Master
The other size I have seen is 10 x 1.0 mm.
- George Ryals
Thanks for the responses - my confusion was with the thread "pitch" - 1.25 coarse - 1.0 fine thread (I'm a hopin) - thanks again - I'll be back with more later - need to source the one into two cable set-up also - plan on new cables but I'll try to find the rest used - all them little parts add up
Norm Taylor
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
When you replace cables, it's best to go with the OEM ones from the dealer. They are better built and are Teflon lined for smoothness. I just bought new under tank brake cable and throttle cables, price was not that bad for the quality.
I have a set of after market units, they just don't measure up as well, they went back into the spares pile.
New OEM cables definitely - lookin to get the gizmo that joins the cables used if I can - not in a hurry, hopefully one will show up on ebay - thanks for the advice
Norm Taylor
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
1980 R100T Airhead
1950 HD Panhead
2003 K1200 GT
