Pressing out neck stem
I have a r75/5, has anyone ever pressed the neck stem out of the lower triple clamp?
Re: Pressing out neck stem
Yes, it can be done. Heat the alloy triple clamp to avoid removing metal in the process and make a note where the lock hole is positioned.
I pressed my 81 stem out recently, without heat, but I was going to make an inverted lower top clamp. It pressed out relatively easy. Just support the underside of the clamp with a close fitting steel tube that will take all the load as you press the stem out.
I personally know of two really good BM mechanics that use this method. Just have to make sure that everything is aligned properly before pressing it out.
