R90S final drive re-seal needed
craydds
Post by craydds »
Please recommend a good BMW mechanic for me. My 1975 R90S final drive needs a re-seal job; a chore I do not want to do. THANK YOU!
Ray
Re: R90S final drive re-seal needed
c8c169be-e941-4703-bdc0-50d4ad7e8f5c_0 copy 5.png (34.27 KiB) Viewed 2687 times
craydds wrote: Mon Jul 26, 2021 11:58 am Please recommend a good BMW mechanic for me. My 1975 R90S final drive needs a re-seal job; a chore I do not want to do. THANK YOU!
What part of the world are you in?
SteveD wrote: Mon Jul 26, 2021 9:22 pm
You're such a stickler Steve, he's obviously FROM THE STATES! :roll:
Zombie Master wrote: Mon Jul 26, 2021 9:42 pm
:D
Left, middle, right? :roll: ;)
I'm thinking right. Maybe Cray will tell us. :)
craydds
Post by craydds »
[/quote]
I am in Las Cruces, New Mexico, USA. Near El Paso, Texas.
Ray
Hmmmm. I would have recommended Hansen's BMW, the dealer local to me in Southern Oregon. Very Airhead friendly and knowledgeable and I'm about to engage them to do the same thing. They also do spline repairs if you need that.
They do work by mail if that's fine for you.
craydds
Post by craydds »
melville wrote: Tue Jul 27, 2021 10:15 am Hmmmm. I would have recommended Hansen's BMW, the dealer local to me in Southern Oregon. Very Airhead friendly and knowledgeable and I'm about to engage them to do the same thing. They also do spline repairs if you need that.
THANK YOU!
Ray
TBexp[2]
Post by TBexp[2] »
Cray:
I'm in the midst of that very job. The reason I'm tackling it is that none of the dealers or shops around here (Southern CO) want to do it. If all you need to do is replace the seal on both sides of the axle the there is an excellent video on Boxer two valve. You just need a heat gun and some bearing drivers and a rubber! (not steel) mallet. Oh and a couple of 5mm x 15mm long cap screws to push the drive apart once you have it out.
If you need to replace the seal between the rear drive and the swing arm, then special tools are needed.
This video is for 85 and later but it is really helpful. William's enthusiasm is infectious.
https://www.boxer2valve.com/1981-on-mec ... drive.html
There may be a video for the earlier models. I could not find it though.
Good luck!
