Rocker Boxes
Nourish
Rocker Boxes
Post by Nourish »
Hello. Will the R50/2 type rocker boxes fit the later /7 airheads?
Deleted User 62
Re: Rocker Boxes
Post by Deleted User 62 »
Well, while they do share the same valve cover gasket, the /2 cover is about 1/2" shallower, so I'm guessing there won't be enough room for the rockers. On the other hand, the /5 valve covers would work.
DanielMc
Re: Rocker Boxes
Post by DanielMc »
I'm no expert, but if you take a photograph of the post you're posting on the forum and then post the photograph of that post in the post you just posted isn't there a risk of damaging the space time continuum?
Deleted User 72
Re: Rocker Boxes
Post by Deleted User 72 »
DanielMc wrote:I'm no expert, but if you take a photograph of the post you're posting on the forum and then post the photograph of that post in the post you just posted isn't there a risk of damaging the space time continuum?
Not if you use the /5 valve covers. They cover all models.
Re: Rocker Boxes
Great Scott Daniel!
Your'e right!
Nourish's clock appears to be fronzen at 8:43.
Now what?
Deleted User 62
Re: Rocker Boxes
:shock: "Never argue with a fool, onlookers might not be able to tell the difference." Just kidding, and if I did indeed tear the fabric of space time, it's really no problem: I have a roll of one sided quantum string reinforced membrane uh... duck tape...
Last edited by Deleted User 62 on Sun Feb 19, 2012 3:53 pm, edited 3 times in total.
Nourish
Re: Rocker Boxes
Post by Nourish »
Thanks for the replies- but aren't the /5 rocker boxes much the same as the /6's?
Deleted User 62
Re: Rocker Boxes
Nourish wrote:Thanks for the replies- but aren't the /5 rocker boxes much the same as the /6's?
Yep, same thing, different year. At least BMW got that part right...
twist
Re: Rocker Boxes
Post by twist »
OK, on a slightly different note but concerning the same area, is there an advantage to be had by polishing the rockers? Are there areas that could be ground down/chase casting and polish? I can only think that polishing would aid in making the rockers smooth and oil would move better over them. Am I missing something?
Re: Rocker Boxes
twist wrote:OK, on a slightly different note but concerning the same area, is there an advantage to be had by polishing the rockers? Are there areas that could be ground down/chase casting and polish? I can only think that polishing would aid in making the rockers smooth and oil would move better over them. Am I missing something?
There ain't much oil flow in there to speed up.
