Rocker Boxes
Rocker Boxes
Hello. Will the R50/2 type rocker boxes fit the later /7 airheads?
Re: Rocker Boxes
Well, while they do share the same valve cover gasket, the /2 cover is about 1/2" shallower, so I'm guessing there won't be enough room for the rockers. On the other hand, the /5 valve covers would work.
Re: Rocker Boxes
I'm no expert, but if you take a photograph of the post you're posting on the forum and then post the photograph of that post in the post you just posted isn't there a risk of damaging the space time continuum?
Re: Rocker Boxes
Not if you use the /5 valve covers. They cover all models.DanielMc wrote:I'm no expert, but if you take a photograph of the post you're posting on the forum and then post the photograph of that post in the post you just posted isn't there a risk of damaging the space time continuum?
Re: Rocker Boxes
Great Scott Daniel!DanielMc wrote:I'm no expert, but if you take a photograph of the post you're posting on the forum and then post the photograph of that post in the post you just posted isn't there a risk of damaging the space time continuum?
Your'e right!
Nourish's clock appears to be fronzen at 8:43.
Now what?
Re: Rocker Boxes
Last edited by Deleted User 62 on Sun Feb 19, 2012 3:53 pm, edited 3 times in total.
Re: Rocker Boxes
Thanks for the replies- but aren't the /5 rocker boxes much the same as the /6's?
Re: Rocker Boxes
Yep, same thing, different year. At least BMW got that part right...Nourish wrote:Thanks for the replies- but aren't the /5 rocker boxes much the same as the /6's?
Re: Rocker Boxes
OK, on a slightly different note but concerning the same area, is there an advantage to be had by polishing the rockers? Are there areas that could be ground down/chase casting and polish? I can only think that polishing would aid in making the rockers smooth and oil would move better over them. Am I missing something?
Re: Rocker Boxes
There ain't much oil flow in there to speed up.twist wrote:OK, on a slightly different note but concerning the same area, is there an advantage to be had by polishing the rockers? Are there areas that could be ground down/chase casting and polish? I can only think that polishing would aid in making the rockers smooth and oil would move better over them. Am I missing something?
