Rear drive question:
Re: Rear drive question:
Post by Chuey »
On the ribbed rear drives that I have, they have a steel sleeve surrounding the stud. The sleeve is 15mm in diameter and sits proud about 1.5mm of the spot faced surface allowed for the shock.
Garnet is right. Though, mine will look a bit different. I'll share a picture when it is further along.
PS (edit) Any guesses as to what the structure is made of?
Post by Garnet »
StephenB
Post by StephenB »
Chuey wrote:Has anyone here removed the stud to which the rear shock is attached? How would that be done? How is it retained in the unit?
Final drive in question: 1983 R100
Thanks,
Threaded in, will simply come out with two nuts locked against each other.
Post by Chuey »
Thanks, Garnet and Stephan. That's what I needed to know. Onward!
By the way, those three pictures were very inspirational!
Chuey wrote: Chuey
You are NOT building a rear suspension out of wood!
are you?
Deleted User 72
Post by Deleted User 72 »
are you?
Maybe...
Deleted User 62
Post by Deleted User 62 »
Garnet wrote:Image
Is it just me, or does the lower mount for that shock look like a failure waiting to happen? The shock should be mounted in line with the U-shaped piece, IMO.
robert
Post by robert »
Sure would be better.
Jeff in W.C.
Post by Jeff in W.C. »
Tim Shepherd wrote: Is it just me, or does the lower mount for that shock look like a failure waiting to happen? The shock should be mounted in line with the U-shaped piece, IMO.
You mean more like what Vanzen did or is doing. I hope he doesn't mind me posting the photo from his site. It is available for anyone to see on his site.
There's more on his site.
http://www.framecrafters.net/show-project.php?id=35
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
Deleted User 62
That's better still, but if it was mine I'd want it in line with the brace, not attached to the top of it.
Last edited by Deleted User 62 on Thu Sep 27, 2012 9:32 pm, edited 1 time in total.
